helicopterjim
- near Lone Butte, BC, Canada
Cheap pudding pot, ear plugs and faith in not crashing.
Who cares anyways?
Jim
Who cares anyways?
Jim
Vince said:I have stuffed this up even when trying them on, too tight and it never got looser so I had to buy bigger 6 months later. What a piss off that was.
I understood that the rear vents were to allow the air to vent out. I found that most of the wind noise comes in from under the helmet, around the neck opening. Early in the season I need to use a fairly thick windproof neck warmer thing, when I downsize to just a buff that I can pull up over my chin, the increase in wind noise is huge. Always use earplugs regardless. A helmet rep once told me that if you get a tight spot (which is often on the forehead), you can use the back of a spoon and compress the foam just a bit, exactly opposite to the tight spot, not removing anything and just a mm or so. On polycarbonate helmets that have copped a whack, the foam can be compressed in to just a couple of mm thick with no visible damage outside, fg helmets usually show any impact very clearly.Richard 180.S2 said:I bought an Arai after having what I thought was an excellent lightweight helmet. The Arai is heavy and noisy and the best helmet I ever had. It's heavy because it's so well made. It's noisy because there are so many wind vents. If you want a quiet helmet buy one without vents but the Arai has front vents, 2 vents above the visor to run cool air through through hair and a top/rear vent to cool the back of of your head. I love it. Yes, it's expensive but I stopped worrying about that after a week.
