Indeed Clem, of the posting here, run the gamut of simple to complex, as actors we have our part to play, doffs me retired Arai to the more than famous Upstart Crow, of a world in plays moment, we play our part.. a smile, well... more of a wide grin...
The 180 series tolerated the BTZ "better" in some regard over the much burdened by BTZ, 120 series. A Corsa of well known Laverda man out here was available to me over protracted periods. Going up a moderately steep mountain and tight curves, being a CR head, torque was very good, the BTZ would cause severe anxiety with the top heavy 120 type bikes, jerking just as you laid into the tight bend, nearly dropped the immaculate Corsa.. no skill in recovery, i was just plain fortunate and quick clutch pull in, rev it and reengage the clutch quickly...as you do/had done i note, Clem
As a side comment, the HKZ burdened with same one step, was rider friendly, for the most part, awaiting the arrival of first on the block Uwe Witt DMC, though Silent Hektik were around similar time, as the more knowledgeable may clarify... The Phil Todd custom Boyer was also early in the history ( been covered previous the real Todd/Boyer against the fakes that appeared ). Regards to all, j
