doublegarage
- California
I'm trying to work through why my (new to me) 1982 180 Jota is hard to start. There's plenty of evidence why I shouldn't trust the PO's mechanical skills so I thought I'd better give the valve clearances and camchain a quick check.
- Camchain play at the slackest part was 16mm - really loose, but adjusting the tensioner brought it down to 10mm (+/-5mm)
- clearances, not good.
in/ex mm
Left 0.18/0.18
Center. 0.18/0.25
Right. 0.15/0.05
should be 0.20/0.25? So all bar one need adjustment, and one is really bad.
I turned the crank (17mm alternator end nut) until TDC on left & right cylinders with the camchain link between the sprockets. I was going to paint some yellow lines on chain and sprockets to help reassembly, therefore checked the alignment of the sprocket-lines with the caps and found this.
Not easy to get a good picture but the exhaust cam is dead on the mark, while the intake cam is off by what looks like exactly one tooth, retarded. (note: this pic is 2 revs past the chain's clip-link being between the sprockets)
That's just wrong, isn't it? I'll get a new camchain when I order the shims but a worn one can't put the timing out that much, can it?
Also, the workshop manual says to loosen all cylinder head nuts - while the green book says just the 12 on the cam-caps. What does the Laverdaforum say?
Thanks as always,
-Richard
in/ex mm
Left 0.18/0.18
Center. 0.18/0.25
Right. 0.15/0.05
Thanks as always,
-Richard
