The spare parts from Red arrived on Tuesday, I went and bought a M16 1.5 pitch high tensile steel bolt yesterday, so this morning i hit the garage with some slight trepidation, worried about how hard it might be to get the alternator off, i had thoughts of bits flying everywhere.. but it all went surprisingly smooth!!
When tightening up the M16, the sprag clutch did what it was supposed to do and slipped, i thought my morning was over as i couldn't figure out how to stop the assembly rotating as i was doing up the "puller bolt" I ended up grabbing a rubber strap oil filter remover tool and putting that around the outside of the alternator, i then got a nice long 24mm ring spanner and a mash hammer! I did the M16 up as tight as i could just by using the oil filter strap and ring spanner, then with a couple of swift hits with the hammer, off she slid... i was very happy at this point untill i started hearing the sound of metal bits falling... yup a couple of the sprag rollers and plungers fell.
I have fitted the new gears, and inspected the sprag, i just need to figure out how to keep all the bits inside when i rotate it 90 degrees to slide on the crank... I played with some duct tape, that wasn't going to work... I then searched on here and found the answer... Grease
In the thread i read, it mentioned no EP grease, but it didn't mention what grease to use, the only stuff i have here is some moly grease... i don't know if that is suitable... so any recommendations would be appreciated.
I also noted when removing the bolt that holds the alternator to the crank there was a lot of threadlock material evident, i need to buy some loctite 243 for the ignition, will this be suitable for the retaining bolt too?
I have pulled the sprag apart it all looks good and more importantly i can reassemble it, should i replace the springs while it is all apart, or leave it? It is a public holiday here in Melbourne for a football game, so there isn't much more i can do today.
Clinkity clink....
Starter gears with all their teeth..
It all looks good, i just need to clean and reassemble it.
