Done to death question, but...
My 750 S is at last useable but carbs would need fine tuning.
I have the seat of the pants impression that it's a bit rich. Very discreet stuttering when on the road. All the brass bits in the carbs are new and to standard specs.
Turning the mixture screws has practically no effect on the engine at idle. I can screw them right in, the engine won't stall. It will if I screw them out quite a bit.
Am I right in assuming that it's too rich, the idle jets passing enough fuel not to need setting of mixture screws?
The engine would respond to mixture screw on rh carb but not the lh. So I changed lh carb assuming the idle circuit was obstructed, now it won't respond either side.
The carbs have been cleaned to death, I've been at it over a year now!
Tappets and timing are spot on.
