trying to confirm proper cam timing, driving myself crazy with degree wheel and dial indicator, now drawing diagrams of the four strokes, bloody hell. For something so simple I seem to be working myself into a lather of frustration and self doubt. While I installed the cam exactly as it came out in relation to the crank, I have no confidence that the original loose assembly of the engine by hands unknown before me was correct, especially with absolutely no cam timing marks, and other errors that I encountered. Like my professional life, never trust anyone or anything without verifying for yourself directly independently.
From TDC, intake valve to open in first 180 degrees, second 180 degrees both valves closed, third 180 degrees both valves closed, final stroke exhaust valve opens last 180 degrees, from 540 - 720 degrees. Then overlap between intake opening while exhaust still closing, and I want to know what overlap is, in additon to what actual cam timing is, as is, then decide whether to crack the cases again, then figure out how many degrees per cam tooth gear, and which direction to change, if any. I am sure those that know what they are doing are laughing out loud reading this......
Tried to use this exercise as an excuse to order another Mituoyo measuring device, this time a dial indicator, but Amazon is out of stock. Further, my enormous degree wheel is intended for a car, which further confuses me, going now to try and find the Laverda degree wheel files that fit DVD and print off, if I can find one..... Had to slip in some Laverda content
EDIT - found the printable degree wheel here
https://www.laverdaforum.com/xf/threads/86485/ I printed it out on heavy high gloss photo stock, nice and sharp, and stiff. I have the first dial indicator directly on the intake tappet. Going to go pickup a second inexpensive dial indicator, mount it on the exhaust tappet, and chart intake and exhaust open and close, overlap, lobe centers. That will determine if cam is installed correctly in relation to the crank.
The intake tappet starts to stir at roughly 70 degrees before Top Dead Center as the exhaust stroke is completing, I understand there needs to be some overlap to help scavenge the last of the exhaust out. 70 degrees seems early to me but I know absolutely nothing.....
As the exhaust stroke completes the exhaust tappet is fully closed by almost exactly 0 degrees TDC while the intake tappet continues to lift. Maybe this is correct, but I am going to do all the measurements anyway with two dial indicators in place. Found a second dial indicator same as my original cheap one, on sale for $12.99, and another magnetic base on sale for $17.99, so will pick up both in the morning. Should be fine for my limited purposes
