Hi Tippie
I am mulling over your explanation. My initial thought is that I have to time the cam to the crank and close the cases before I can install the cylinder to establish where the head surface actually is. Splitting the cases again to alter/correct cam timing is something I would prefer not to do.
I am also not clear on how to place something flat across the tops of both lobes to have that dead level with the head surface, as the cam lobes are rotated 90 degrees from where the head surface will be once the cylinder is installed?
Anyway, lots of time to mull this issue over, will be a few days for the blind bearing puller set to arrive, then have to finish stirpping the cases, source all the replacement bearings, clean up the cases etc before I worry about re assembly.........
I still have some other dis assembly issues to figure out as well.
I did take lots of photos of the location of the cam lobes to the drilled holes in the crank and made some marks so hopefully things will line back up, we'll see when the time comes.
Steve
"crowded rollers", hmmmm, the inner race is pressed onto a post, the outer race is the inside of the gear, then there is a top and a bottom, both flat washers each with a locating tab to prevent them from rotating. Unless I can source brand new gears for the two gears (together with matching inner races) with this roller arrangement, I suspect I will try to find new rollers and call them good..... The various bearings in the engine cases are all "crunchy" and have to be replaced but the crowded roller units actually seem decent, fingers crossed.
My planning may be a little ambitious, but if I get the frame and all the other painted parts back by end of February as promised I am hoping to have this bike re assembled and running by mid May so I can start the "sorting" process. If specialty Gilera gears and races have to be sourced from Italy with long supply and shipping delays I will likely reuse those two "crowded roller" gears , especially if I can at least source the loose rollers locally.
Paul LeClair
