lavgert
- Vienna, Austria
Hi Paul, nice little bike - congratulation! I bought the 2.50x19 tires and tubes for my LAVERDA 100 Sport Lusso here: https://italianclassictire.com/en/
Ciao, Gert
Ciao, Gert
Seems to be a french thing... had a french 3CL in the shop last year, front wheel had a terrible wobble starting at about 60 km/h. Tried balancing, but 100gr. wouldn't even get it close. Pulled the tyre and tube to find a heavy-duty motherfucker of a tube (Michelin of course) suitable for the Paris-Dakar. Replaced it with a normal tube and all was good after applying about 10gr for balancing. The Michelin tube alone added 1 kg of un-sprung weight.Get quality inner tubes as well. I use motocross or enduro tubes now. 3mm rubber.
There's a shop in Italy, but that's a long way from you. Italian Classic Tyres. Excellent service.
Clutch pull likely cable related.
Rode my SF2 all Summer with my enduro tubes Piet.Seems to be a french thing... had a french 3CL in the shop last year, front wheel had a terrible wobble starting at about 60 km/h. Tried balancing, but 100gr. wouldn't even get it close. Pulled the tyre and tube to find a heavy-duty motherfucker of a tube (Michelin of course) suitable for the Paris-Dakar. Replaced it with a normal tube and all was good after applying about 10gr for balancing. The Michelin tube alone added 1 kg of un-sprung weight.
Moto-cross tubes are not meant for prolonged high-speed use and are therefore apparently not made with an emphasis on precision. The removed tube had irregular wall thickness which could be felt by running the tube between your fingers. Inflating it brought the irregularities to light.
A tiddler might not reach speeds at which tyre balance becomes a real problem, but I'd be very, very wary anyway.
BTW, Heidenau tyres are quite good quality, as are their tubes. Most tread patterns are based on old, discontinued Metzeler patterns and they don't do anything above a "H" speed rating, which is irrelevant in this case anyway. "Vee-Rubber" (Thailand iIrc) inner tubes are great value and are of a considerably thicker guage than most european brands, possibly to cope with the road conditions in the asian markets.
Yep, them's often like that, Paul LeC. Work well.That chain pull throttle is common to many Italian machines of the period.. Super Pratic Flash. I have those on my Laverda singles ...
That's often the case.Thankfully it looks like you have clear access to the points. My worst nightmare was a bike that had the points inside and behind the flywheel, assess was through tiny holes in said flywheel. Painful memory.
Really!!!…If it's a points ignition, it's through a window in the alternator rotor for setting. With a cigarette paper says the manual.
my but that is pretty..... on my recently acquired very small bit of Gilera 150 knowledge that appears to be a Turismo 150, different front forks.Picked up this afternoon from the Guzzi singles list.
Something to aim for.
PaulView attachment 60704
Not to mention the different seating arrangement ....on my recently acquired very small bit of Gilera 150 knowledge that appears to be a Turismo 150, different front forks.
