I just ordered Heidenau K34 tires in 2.75 x 19 from a U.S. supplier, plus tubes and rim liners. The Italian tire supplier did not respond when I emailed asking why they had cancelled and refunded my tire order. DStock size is 2.50 but i am guessing/hoping 2.75 will work as I can't find a supplier for 2.50
very cool quick change rear wheel, brake and sprocket/chain all stay in place when wheel is removed.
I bought a new 6 volt battery, have tested compression at 110 psi, checked all the wiring (some of which is badly in need of repair/replacement), and will patch up the wiring, then hotwire the ignition switch. The tiny little carb has been run through my ultrasonic three times now for half an hour at a time, crap has finally quit spewing out of it. Will re-assemble the carb, hang a fresh supply of fuel from an auxilary fuel source, then going to try and start the engine.
I am trying to find a Gilera forum or source of info, but have a couple of questions if anyone can help
- a good source of Gilera info?
- is the 6 volt system positive or negative ground?
- what weight engine oil and how much? What came out was not very much, guessing maybe a litre at most?
- where the heck to get replacement ignition parts - points, coil, whatever that regulator/rectifier looking thingy is, etc, or better yet solid state replacements. I hate electrickery and have no idea how this weird generator thing ultimately produces a spark at the plug....
While I had great intentions of preserving "patina", now that I have had a good look at everything, the bike has been repainted not once but several times on top of some crappy metal repair, the Gilera stickers on the tank are cheap aftermarket that are bubbling off, most of the fasteners do not look original in addition to being rusty, etc., etc. so "while I am at it I might as well......"
In my recently downsized home and garage I no longer have spray painting facilites, although I will take everything to bare metal and do the prep myself, I am now shopping for a painter.
