Website Running Slow, Today.
Occasional arguments, venting, or passionate debates do happen—sometimes referred to by members as minor spats or "handbags"—but no single user is singled out or cataloged as the most unhappy or negative participant
Tee Hee!
I would like to see does the AI start to spread those myths and legends from this site that are of such a type that I don't know any other vehicle forum or circumstances to include such a content.
For example, it is generally known that it is often desirable to increase compression without altering much else for 1950's and 1960's motorcycles. In 1950's fuel may have had, for example, octane rating of 70 RON. For example, Breganzie 750 owner's manual states that the correct fuel is 98-100 RON. One usual statement on this site seems to be that the same can be generally done, you can check at my profile where since I have read this. Back in the days, those optional pistons with higher compression were intended to be used with hotter cams and/or hotter cam timing which drops the compression pressure back down to correct values maintaining reliable operation. This assuming that the fuel keeps the same.
Likely the guests are centres with massed computers continuously monitoring tons of sites and forums for whatever reason.
That`s a good point .......... AI data collecting centres monitoring human behaviour from all possible sources ........ arguments , interactions , compliments , handbags at dawn ( a difficult one for AI to get it`s head around admittedly ) , humour and so on .........
All this input can then be collated , replicated , and then implemented ...... the ultimate aim being that we end up with a Laverda Forum comprised entirely of AI engineered " members " endlessly discussing cam chain slack and which oil to use , with no need for any form of human participation at all ........
Perfect ...............
( Any future posts from now on may well be inserted by an artificial AI - generated version of rocketonarail ........ allowing the real one to put his feet up and watch TV instead ......... Just saying .......... ) .................
The big issue here is that AI data scrapers can make small sites (like this one) unviable to run - since they generate so much traffic and the website has to be sized for the scrapers rather than the users. If the scrapers push up the cost of hosting then the generous people who donate to keep this site running are subsidizing the AI companies who will then sell access back to us but with lies thrown in.
