G
Grant
Guest
It's all too easy to ground the primary chain adjuster lock nut, and the sidestand seems to sit a lot lower than the nut so I would recommend being careful on left handers until you ascertain if/when it decks out.
2volts said:Rob,
It's a fine line between patina and scruffy.
I was happy riding an original but lots of patina bike for a while but ultimately I got sick of riding a scruffy bike.
Then there were things I wanted to do to it that required engine out and a bare frame and I only wanted to do that once.
pete
motoddrob said:Good point Dave. At least it'll protect the primary adjuster nut from being torn out therefor not leaving a trail of oil for me to loose the front end under brakes slowing for the car park of the Mundaring Weir PubLucky for you that left hander wasn't too far from the pub otherwise you'd be replacing more than just the primary cover
lawrence said:A float needle/seat was leaking on one of the Mikunis. I pulled the drain plug on the offending carb float bowl and fired a few bursts of 90 psi air through the fuel line. Apparently that did the trick; no sign of fuel in the overflow tube now. Plug back in, turn on the taps and she fired up at the touch of the button!
At this point I need to fit some mirrors on the old girl, fill the tank, then we're ready for a new riding season.![]()
It may have been the result of extended wide open throttles with fuel roaring past the needle and seat whilst in pursuit of the mighty flying Kangaroobreganzane said:That might fix it but bear in mind I recently helped with a set of Miks which had (after quite some mileage) damaged the tips of the float valves enough that they would pee themselves. Unlike a Dellorto with the somewhat more forgiving rubber tip, the Miks have a metal tip on the float valve. The metal tips had a tiny line of damage (just enough to get a fingernail to snag on) around them which seems to have been enough to make them leak and overflow sometimes. Whether this was from vibration during riding or the bike's long transport journey is unclear.
The worn ring around the needle from contact with the seat was very common when I was in workshops, and I have seen a few classic racing people who have had to replace needles and seats in CR racing carbs for the same reason. Nothing to do with dissolving seats though, wear and tear.breganzane said:That might fix it but bear in mind I recently helped with a set of Miks which had (after quite some mileage) damaged the tips of the float valves enough that they would pee themselves. Unlike a Dellorto with the somewhat more forgiving rubber tip, the Miks have a metal tip on the float valve. The metal tips had a tiny line of damage (just enough to get a fingernail to snag on) around them which seems to have been enough to make them leak and overflow sometimes. Whether this was from vibration during riding or the bike's long transport journey is unclear.
breganzane said:Whether this was from vibration during riding or the bike's long transport journey is unclear.
