Schurminater
- Surrey Hills
Laverdian said:Simon check the contact faces on the fuse are clean, especially since the bike has not been used for some time. The fact the one horn worked when you disconnected the other suggests the current draw for two horns was insufficient across the fuse. Encountered the same problem with the RGS last year and this was the root cause.
I had this issue with mine too,they seemed to work okay then when i really needed them at the m.o.t test they didn't work.....remove one wire from 1 horn and the other one worked okay,I couldn't work it out as occasionally they would suddenly work again....it kept happening and in the end it was down to the horn relay that i had fitted incorrectly so that the full voltage wasn't passing through to the horns.
So worth checking on that if you have one fitted.
