Might be at 90 degrees when the shoes come in contact with the drum, that's how I used to set mine up back in the day.
That'll be a long pull on the lever though.
Is the lever arm on the front brake fitted on a spline that you can adjust? You'd get better braking if the angle between the cable and brake arm was closer to 90°.
Yes, it needs to come off again. The lever isn't fitted on a spline. The end of the actuating rod is square so there's only 4 positions. I need to get inside the hub again.
Lockdown..?
I thought it was only a couple of earthquakes and a tsunami :unsure:
Didnt realise it was so serious...
Looks like you have it under control but.
So big day at Laverda central, west depo. Second-year without a shim change, only one head bolt needed nipping up, slight adj on one carb with synchronizing, and the fitting of a front brake light switch rubber cover and a Voltage gauge on the dash. Good timing for that gadget as it indicated the bike was only being charged with 2 phases. A well burned wiring connector to the regulator being the cause. So happy to be now ready for another big year of LAVERDA RIDING, thanks again to that man with the spanners.
Has the snow melted there already, Vince? Still got a month or so here it seems.
No Snow, I said to my brother the other day, thankfully we have cracked another Summer. We had some crazy hot November days but thankfully it's been a typical slightly wet and mild La Nina year so far, and a record year for farmers. And now it's cool it's the best riding time of the year.
