Just drilled out & riveted on a cheeky pair of condensers- Fiat 126 fitmet..new Bosch coils, new plugs, oil and sump plate, 50 pilot jets ,time her up and hopefully last years poxy misfire will be a thing of the past.
It's best to bolt the condensers on. The rivets work loose with vibration and the condensers earthing through their body, you get a frequency related misfire.
The entire fairing sits at a flatter angle than the previous fitment... quite obvious from your old pics. Compare the fairing trailing edge to lower tank edge.
Yes, I came to the same conclusion. The fairing needs to be tilted down at the back.
I need to undress the lady again to have a look at her suspenders.
Paul, I reckon your head light pointing down is because the fairing is sitting too high at the back. Compairing the photo you posted with mine the back of the fairing of yours is level with the bottom of the tank where as mine is level with the bottom of the fuel taps. Your 2nd shot of as before also shows the fairing sitting lower level with the bottom of the fuel taps.
Could be the front mount fitted up side down which would raise the rear. Worth checking.
I've searched all my pics for some of the original front fairing bracket, to no avail. I came across these however taken during rebuild. Is that bracket the original one repainted or is it another part?
Is it on the right way? Bolt is underneath.
I have doubts about that part.
Or maybe the fairing is wrongly drilled?
  • Like
Reactions: Jo
Thanks, I'll give it a try as soon as the temperatures leave 0°C and when the roads have dried a bit.
I'm beginning to be reconciled with the thing.
When I at last got it back, after 5 years, even though the work was high quality, it wasn't quite my bike.
This was my bike.
and then, this
Getting my grubby little hands in there after having taken her clothes off has made us more intimate.
:love:That will happen, given she approved.
Now, I'd like to know why that headlight appears to be pointing down.
BeforeView attachment 61518
And afterView attachment 61519
The headlight is pointing downwards because the whole fairing is pointing downwards, Paul. The wings should be lowered at the rear by at least 50mm. Indeed the headlight must be in a vertical position. I hope that doesn’t implicate the holes in the fairing nose need to be redrilled, maybe you can do it with spacers, but I fear.. 😬
Marnix
Marnix
That's the conclusion I came to Marnix. I'll try to reposition it, otherwise, it'll be filling the holes and paint.
Just noticed there already were similar replies. You could try bending the bracket that is bolted to the headstock a bit..
Marnix
Was out today Paul 😀 it’s a great bike but then you might not know that 🤣
Damn right. Even at the "50th" in Breganze in 97, I didn't try one. Must have been a premonition. Even when the French importer was selling them half price, I wasn't tempted. His stock was bought by Enzo, the Belgian importer who's now selling off all the broken remains.
The 500 already has enough auto destruct features not to warrant another 40 HP and a lack of planning and quality control.
Marnix
I wonder if the rubber silent blocks are fitted on the wrong side of the bracket? My SFC is not together at the moment so I can't go look to verify. That would account for the 50 mm as best as I can say.
Perhaps the silent blocks are not even in place ........ the photos show the fairing bottom level with the bottom of the tank and the original photos show it as you say about 50 mm below the tank.
Hope it is an easy fix Paul.
Jim
I have some pics of the resto of the bike showing the mounting of the fairing.
Seems to start off ok.
( Borghesi book for reference is fun)
Came across this photo. My first track outing at the Coupes Moto Légende, Monthléry 1994.
Alongside an ex Bol d'Or Kawasaki of some sort. There was in that series for exceptional bikes, 6 of us. There was the Bol d'Or Moch Benelli/Motobécane 6 and a lovely Velo KTT.
In France, the gesture uniting thumb with two fingers indicates fear.
I'd had the bike for a year. It was then that I learnt that using SF valve springs with 6 coils rather than the SFC springs with 5 coils leads to binding at high revs because of the high valve lift..
Came across this photo. My firts track outing at the Coupes Moto Légende, Monthléry 1994.
Paul if you can fit on an SFC a Zane will be a breeze - never give up on your body !
