chrisk
- Brisbane, Australia
Apart from the wheels looking pox (imho)
Agree Dave.
The jury is out on the wheels….. they’re all throwing up in the Courts toilets.
You mean Schultzy, Dave?Apart from the wheels looking pox (imho)
Twas a lovely paint job.
As Kernal Klink would say………
You’re right. Tom Quaye managed a near on 99mph lap at the Manx on this bike, the quickest lap by a SF based bike at the IOM.Very effective looking SF-based racer.
Using Yuasa AGM had a good run so far, changed the one in the Jota only because it was more than 6 years old and didn't want to get stuck 700 Ks from home.got two Yuasa's a year or two ago for a tenner each, you might remember you named Dave Finch the truffle sniffer, one failed fairly quickly and wouldnt even do ride on mower service, the second one is still going strong.
Anyone else still using them?
Found a dirty old bike at the back of the workshop that hasn’t seen serious use for a few years. Gave it a bit of a clean, will get it back on the road in October (likely to get snow next month) and see if I still like it. Otherwise could turn it into a bar leaner. BTW, has one of those yellow AGM Motobatts fitted November 2012 and starts a charm. Only battery I have tried in the Jota that gives good cranking.Great roads, had a fat time doing them 4 years agothis years 2 day excursion around the alps with the Jota was a little wetter than last years, had to turn back at the Großglockner, Brenner and Timmelsjoch passes due to land slips. Bike performed without a hitch of course, great trip. Was almost as wet as the run down to Breganze earlier in the „summer“
It isn't, as John notes - you need volts as well as amps to get a successful start! But having said that, CCA is not a bad indicator of suitability to the task. A triple starter will take around 170A when cranking with a cold engine. Add in the effects of an aging battery with reduced capacity; poor charging regime; old wiring with increased volt drop and you're quickly running out of road. Not to mention a starter motor that's never been overhauled.I seriously dont think that 240CCA is needed
Get yerself a 750 Zanè, Clem, and discover how every little bit of extra ooomph is most definitely needed!<snip>
I seriously don't think that 240CCA is needed ...
I've seen Bosch starters gobble 240 and more amps... with the engine only just turning over.It isn't, as John notes - you need volts as well as amps to get a successful start! But having said that, CCA is not a bad indicator of suitability to the task. A triple starter will take around 170A when cranking with a cold engine. Add in the effects of an aging battery with reduced capacity; poor charging regime; old wiring with increased volt drop and you're quickly running out of road. Not to mention a starter motor that's never been overhauled.
My old Odyssey PC680 sees a minimum terminal voltage of 10.4v when cranking and delivering 170A (which coincidentally happens to be its CCA) - voltage tends to rise once the engine begins to turn. Worth noting that CCA claims by some manufacturers are not reliable and spurious when talking about lithium based cells. I usually recommend a 16Ah lead acid battery as the minimum for a triple.
