piranha-bro2
- Melbourne
Been there done that Haggis. Several moves and each time a workshop downsize!
See if you can convince the lady of the house to throw away a little moreI'm currently dismantling and packing my garage for a house move. Jeez, what a lot of stuff (shit)Decisions - what to bin versus what to keep - agony! The new place can't take it all.
Thanks, as far as I know no radical changes were made after the rebuild other than a re-setup of jets, ignition, spark plugs, to match the CR etc. Mine has the 2 base gaskets -also had to do with the cam chain tension. Glad it was in that magazine so they measured compression for meShaving the head or fitting a smaller base gasket will raise the compression (yes, by reducing the combustion chamber volume) but won't alter the shape. I shaved 1mm from my SF head and ran a 0.15mm base gasket to get 10:25 CR - I'd buretted the chamber and it only had an actual CR of about 8.5:1. Simple way to reduce CR is to fit thicker or two base gaskets. Raising CR and not rejetting raises the risk of holed pistons. I wouldn't have thought 10s in plugs was necessary, but whatever works. I still wouldn't run 8s in an SF unless it was going to be dawdled.
Thanks! Apparently the engine was thrown together before my father got it, though it did run, for a while anyway (it came from a running GT). But didn't last long with the heavy side car apparenty. It was only after it broke my father found out about all the things that caused it & rebuilt it with advise (and work, e.g. crankshaft) by Gijs. It was many years ago and it has run great all those years after it was correctly set up and maintained.There are many factors to count in when shaving heads or otherwise modifying the top end of an SF. You will have to be very careful if and when you freshen it up. Shaving the head more than a small amount can bring the top lip of the cylinder sleeves in contact with the head surface, which can cause gasket problems. It can also bring the squish band, the flat part around the outside of the piston crown with the corresponding flat in the combustion chamber, under the vital 1mm minimum clearance needed on these motors. It also brings the valves closer to the piston, sometimes causing contact, depending on cam type or timing. Adding more base gasket material helps in some ways but is not the ideal solution. Then the motor needs carburation, ignition timing and advance that suits. There are many things to be measured and checked, it can't just be thrown together with bought parts (your dad had advice from Gijs), but hopefully you will never need to go there. As it is going great and does not appear to have any problems, just enjoy it.
Hi Gerald, did you buy online or at your dealers shop? You find a lot of fake NGK spark plugs in www.Been having an issue with the ignition on the 71 SF. Would pop and bang, often cut out under load.
Did all the checks, valve clearance, carb balance, ignition timing ( Boyer) and spark plugs ( NGK B9ES).
Mate up North recommended to try Champion NC3 instead of NGK.
All problems resolved, no popping or banging, pulls like a train.
Bad batch of NGK sparkplugs?
Gerald
Gert,Hi Gerald, did you buy online or at your dealers shop? You find a lot of fake NGK spark plugs in www.
Fake or not?
How to identify counterfeit spark plugs: Check these 5 features: 1. electrode, 2. cutting marks on caulking, 3. Smudges, 4. LOT number, 5. c-groove markswww.ngkntk.com
Ciao, Gert
Nice one Hamish,I use a Morgan Carbtune too brought mine second hand from a guy who had 2 sets that he used to tune some V8 engined Capri up with.Anyway he was happy to split the pair up and sold me one.Yesterday, actually.
Balanced the carbs. I had bought a triple set of gauges from Davida many years ago. I finally got around to using them last week.
Clem's reservations about multiple gauges were justified. Two of the gauges were close, the third reading much less. I was able to establish, by switching the hoses that one was indeed duff. Unfortunately, by then, I had put the adjustment way out.
So, I bit the bullet and ordered a new Morgan Carbtune Pro 4. It requires a little fettling: cutting and fitting damper tubes in the hoses, but they did their job and the carbs are back where they ought to be.
It's time to replace the original Dell'Ortos with a set of Keihins.
If Keith's consumption claims are correct, the switch should pay for itself within a couple of years.
Running 9:1, is there a reason you want to run 10s??? Or have we discussed this already? Surely 9s would be fine? i've run 10.5:1 on 9s, zero issues.Speaking of spark plugs, those B10s my GT has are special order which I'm not too fond of. Local guy (mostly mopeds/scooters) has Champion & a conversion table, but was wondering if something more common can be fitted to my bike with it's history of non-standardisms...
Champions in that range are also special order & may take a while.
Any advise? I can of course order B10s & keep the current ones as spare, but something more common may not be a bad idea.
Pistons are as far as I know standard GT type but compression ratio is ~9:1
Lean it out far enough and one might even NEED 10's...Running 9:1, is there a reason you want to run 10s??? Or have we discussed this already? Surely 9s would be fine? i've run 10.5:1 on 9s, zero issues.
