Well, apart from being soothy (always), I just inserted these B9ES as they were told on here to be the correct plug heat grade for an SFC1000. I have used B8ES in my former RGS as well as my SFC1000 for decades with no melted pistons etc. so far.
But, better take the advice from the experts. So I bought a box of 10 B9ES and am now trying them out.
Apart from that, brass is new, gaskets, slides, jets, needles, floats are straight and set at 18mm, float forks are not too open, idle mix screws are new and set to 1,5 turn as recommended, though I just set them to 1 1/4 turn to try and lower soothyness, needle clip are at the middle notch, 60/2 slides, 265 atomiser, 118 main jet, 65 idle jet, acceleration pumps are installed and functioning well, all syncronised with my carbtune following procedures.
Standard paper air filter always clean fresh one, 2 * 40mm holes in bottom of airbox from factory, 40mm downpipes and 2 Jota end Cans.
Motowitt Mk 1 ignition, and I don't remember which curve right now, but it's standard.
Battery always charged fully and plenty of cranking amps. Schnabel voltage regulator as Nippo Denso burnt off like they always do.
cams are pretty spot on, so are valve clearance, primary chains and cam chain adjustment. Ignition pickups are original and adjusted to be pretty spot on.
Valve springs are Motodd 1/4 round less, same length. Bikes done 43000 km i total. Always fresh oil every 1500 kms and at least every year. No oil consumption ever. No smoke from anywhere.
Inlet tracts are swapped to 36mm aluminium ones and rubber connectors to carbs. Fits perfectly.
Carb top screw tight etc.
Choke plungers lubed at assembly and have a bit slack so they sit tight at the bottom position. Only ever use the chke function as a start aid device, around ? way and after 5-6 seconds off, just keeping gas a bit open while Warming up a Little bit.
Bike starts easy hot and Cold, and accelerates really well, strong pull from 1500 rpm to 8400. Smooth and calm stable idleing as well.
To prevent valve clearance distortion, I have always used Castrol Valmemaster + (ocatane version) plus used Shell Vpower 99. Tried anoter brand once for one tankfull, but same result.
Still soothy plugs.
Ggrrrrrr ;(
Could it be a good idea to go smaller in idle jet size, say 62,5?
Lower needle (K1) to lowest position?
Can deceleration letting go of the gas roll make sothy plugs?
Any suggestions?
Kind regards,
Jacques
