SFC1000 day and a stroke of luck with the 1200TS
Cleaned the inside of my SFC1000 headlight, which given it is a semi sealed unit was not so straight forward but what an improvement.
Replaced a faulty high beam warning light bulb with an LED.
Pulled apart the LH switch gear to make the horn work - it was all about getting the thing to earth properly and seemed harder than I expected, but horn is nice and crisp now.
BUT the biggest celebration was when I took the 1200TS for a ride. It has been over-revving at tickover - it stays high when I pull up and then falls back to normal and I was convinced this was because there was an air leak at the inlet manifold. So imagine my surprise when I leaned forward on the tank at a red light and the engine revs increased - and so it was, the Mikunis clearance to the tank is so fine that it is prone to touch the throttle mechanism and increase the tickover revs, but from time to time it will drop back to normal. All confirmed by pushing down and lifting the tank up. Saved a lot of mucking about that did.
