piranha-bro2
- Melbourne
Smicko, Marty!
It is all orange body work, was in a local ford dealership on display a couple of years back. Sorry don't have a photoOne in the pic is about 95% blue - thought this one looked 95% orange. Awesome beasts.
I’m digging the colourSF2 seat lost its lid. Looks much cleaner now.View attachment 59012
This is a good material, that is also used as a heating hose in Humvee's with a slightly larger diameter.Added some nice intake pipe to my Formula - the old ones were fecked and air was not coming in cold from the front
Hi Thomas i used a bigger sleeve on the fairing end as the pipe i used is ID 38mm - its a push fit into around 7cm - holds it firm but should pull out easy enough - not taken the fairing off yetThis is a good material, that is also used as a heating hose in Humvee's with a slightly larger diameter.
The empty shell of a silicone cartridge has exactly the same diameter, as the hole through the frame.
If you then work with two shorter pieces of hose, you can easily remove the fairing as the inner hoses do not have to be dismantled.
View attachment 59156 View attachment 59157
Thomas aus LAU
Hi Thomas i used a bigger sleeve on the fairing end as the pipe i used is ID 38mm - its a push fit into around 7cm - holds it firm but should pull out easy enough - not taken the fairing off yet![]()
That's what everybody is telling me Clem. I sent the original plate back to Joe who intends mounting it on one of his bikes. So, we'll see if it's the plate or the frame.I wonder why your plate did not fit Paul, when hundreds have been made that do?
bit weird is that, mine went straight on.
