I can't afford it.
Just rebuilding the TT2, which has a new engine is time and money.
And then, if the rider crashes it, there's a lot of pezzi rarissimi o cari on that.
I know, I race my Harris 600. That’s why I am not expensive to hire.😂
If the project is overwhelming ………
The plastic toe piece finally gave up after 40+ years. The thread stripped out. Found some 20mm ally rod and half an hour on the mill and linisher came up with this. Temporarily fix till I get a replacement pair.
I used a custom toe piece with a UJM rubber in place of the shoe-destroying Jota knurled alu thing. Then Piet gave me the RGS plastic one you speak of Rob. I like your alu replica!
Me too, a perfectly good expensive Alpine Star Gore-Tex boot died from its hole worn from the knurled toe piece on the top of the boot. I got a replacement toe piece made smooth with a rounded end and zero knurling.
First job on my list of a little bit of restoration re-paint the pipes and silencers was very nice to see that they are original Sito
the label appeared whilst stripping off the old paint 👍 all ready for spraying tomorrow.
FIrst ride tomorrow around my test track. So looking forward riding it again.
Have to say the ignitech ign has tranformed the motor. No longer walks across the floor when reving, idles better and less vibration through the throttle.
Great stuff Rob, finally let it out of jail. One SFC I serviced had the bloke pissed off because it idled, reckoned that it was a racing bike and I must have de-tuned it to get it to idle as it never had before.
.....too kind Vince, one of the aspects that came about unexpected, was the actual idle capability of the triples, carby re calibration a given as next step post ignition upgrade. Cold crank start and idle ( hands free on the throttle ) 15-30 seconds you could walk away and kit up, the series 1 motors responded well, the series 2 a little more careful setup.
The biggest overall outcome post bosch ignition, protection for the starter clutches. BTZ did more damage to starter clutches than poor low throttle response. Batteries well taxed having to crank and crank while the BTZ output a feeble 15KV at best to fire a cold crank enrichment, anti start "ballast" resistors making horrible into fiasco. j
  • Like
Reactions: pf1
