Tetley Laverda said:Did the Laverda factory turn out any engines with polished con rods
Thanks Tetley
Only the 750SFC to my knowledge. And the TT F1 RGS.
Thanks Tetley
Vince said:Learnt my lesion on a 64 Bonnie,went to start it and couldn't kick it through,completely full of fuel,top and bottom
Laverdalothar said:I even turn them off roughly 500 meters before I get home. This makes sure the float bowls get fresh gas when I turn the fuel tabs on next time. Better starting, no issues. :-*
Surely the problem is the lack of overflow venting on the Del Orto's? Inspecting my set, there is nowhere for the float chambers to drain other than the cylinders. Mine now have a judicious 5mm hole drilled into the float bowls just above ideal fuel level. Serves two purposes, allows exact setting of fuel level in the floatbowl, and any overflow goes out down the pipes to the floor. (Just as every Jap carb has had since they were first designed). (Doncha just love Italian engineering).
