Jota996
- Northumberland
As the title says really just looking for some advice
Stu
Stu
Dave "SPIDER" Holder said:I was initially looking at it from a cost point of view to be honest, (pensions in the UK are shit) I haven't had a problem apart from those awful Bosch boxes making the thing a pig to ride at low speeds, so, as far as the pickups are concerned, if it ain't broke, don't fix it comes to mind. As the original post asks, what's the general consensus on what is readily available and affordable in the UK.
Dave "SPIDER" Holder said:From my internet searches, the DMC is the most expensive, followed by the Sachse and, if I am correct, the Ignitech the cheapest. If the Ignitech TCIP4 uses the original pickups on a Mk2 1200 and it just plugs in without mucking about with the wiring, then that sounds good to me, but where in the UK can you buy one? everything I can find on the web is based in Aus or CZ and postal costs are ridiculous. Or am I missing a trick here?![]()
Of course you can but it aint as simple as that also the beauty of the ignitech is that you can dial in your own to suit.Dave "SPIDER" Holder said:Cheers Piet, good info to know.![]()
Question; would you be aware, if the curve profiles are sorted on the Saches/Witt/DMC, then is it possible to copy those profiles to the Ignitech? (A reasonable grasp of Computer savvy being taken for granted here) or is that sort of information, "classified" in respect of Saches/Witt/DMC, I have seen the differing curves graph on the Saches instruction leaflet, but not from the others. This is an A11 cammed 1200 we are talking here,,, road use in the UK only.![]()
