- Calgary, Alberta, Canada
I have owned my RGS Executive for quite a while, rebuilt the motor, swapped and rebuilt different sets of carbs including a set of Mikuni RS flat slides, then a few years ago I went back to a set of Dellorto's. I know I am the one that built the carb rack presently on the bike.
Now that the Guzzi is done, i am getting the three Laverda triples ready for the spring, starting with the RGS. Put the RGS on the lift table and pulled the carbs. Amazing how filthy nasty dirty they are, and the float is stuck on one carb.
I started to strip the carbs to run bare carb bodies though the ultrasonic and found that one of the allan head fasteners holding the carb body to the frame that holds the three carbs together has an allan key end broken off in it...... Has to have been me. I have no memory of it. Bloody ham handed amateur that built up the carbs last...
tried to drill the broken stub end out of the screw, seems to be harder than my drill bits. Gave up and stuck the carb body in the ultrasonic still attached to the rack. Look like I am going to have to weld a small bolt to the screw head to get it out.
