stevepm2011
- Cologne, Germany
G'day all,
I am in the process of fitting a Witt DMC2 to the 1200 TS.
Can anyone offer advice on where best to put the box?
At the moment, I can see a few options:
Under the tailpiece - should stay dry, but no great cooling airflow, long wiring runs
On the inside of the rear mudguard - should stay dry, but don't want to drill the mudguard (corrosion)
Up under the tank somewhere - stays dry, but tight space, too hot for electronics.
On the inside of the RH battery bracket - maybe not quite dry, but the Odyssey battery doesn't need the room. Probably my favourite.
The New Zealand variant: attach it to the oil cooler using no.8 fencing wire, wrap it in sheepskin to keep it dry...
Any thoughts?
regards,
Steve
Any thoughts?
regards,
Steve
