martymoose
- Sydney, Australia
I could tell you Q but then I'd have to kill you......
Is the conversion more than a well-sealing rim tape? Please share details.Sf2 enduro converted to tubeless with a right angle valve. Now you really want one don't you Vince.......
Conversion has been tested for 5000km now, no problems.
I've never seen that. Sounds like a tyre valve waiting to be ripped off by a rock or something.... simply drilling through the tyre sidewall so the tube could creep/spin with the tyre at their impossibly low inflation pressures.
I'm seriously thinking about a trials bike so I can ride over them.you don't have traffic in Melbourne?
Yep, did that on sliders. When down to 6psi on a slick track, with the wheel spinning the whole track length, something had to hold the tyre in place.One of the ye old off-road tricks to stop tyre creep at low pressures was to drill the rim edges and insert short self tapper screws into the tyre sidewall. The trick with using super low pressures required by Radial Trials tyres, down to 5 psi is using 2 rim locks. Too much creep and it tears your valve out of the tube. It helps to not do the valve rim nut up tight as well.
Tubeless - not a prob.90 degree valves on the Benelli Tre and some of the Zane bikes. No issues with them (yet), but that’s perhaps because I ride them soooo slowly...![]()
