bclark
bazzee said:It's late, and I'm not focussing so well, but looking at the images in the link there are 3 inlet manifolds but 4 exhaust pipes.
The T160 Triumph Trident had this configuration also..
Clumber981 said:Ok its wasn't a road bike but MV had their stupendous race triples.
I'm sure there must be some more road bikes if you went back to the 30/40/50s/ when all manner of engine configurations were tried.
bazzee said:If I understand it correctly, if the same principle is applied to an inline triple then the ideal crank spacing would be 120o.
bazzee
breganzane said:bazzee said:If I understand it correctly, if the same principle is applied to an inline triple then the ideal crank spacing would be 120o.
bazzee
Nope, the "crossplane" concept is basically to produce an odd-firing order - achieved in a 4-cylinder using a 90 degree crankshaft. A 120 degree triple is an even-fire. The point of my raising this is that to create a "cross-plane" triple, the most logical crank phasing and firing sequence would be the same as the 180 Laverda triple (which was "odd-fire").
That is of course unless they do something even weirder like a 90 degree crank, effectively giving 1.5 "twisted twins" ala TRX850.
Either way I reckon it'll be an interesting engine.
SteveB
Grant said:The IDEAL crank throw for a triple is 120?, but in practice some cranks are designed with non-ideal crank throws.
Why would they do this?
It started in dirt track racing long before it became trendy with the 500 GP and then MotoGP bikes.
They used take Brit twins and rephase the cranks to replicate the H-D bikes, that were all conquering.
The theory was that a staggered crank throw allows the tyre to recover some grip before the next power pulse hits it.
I think the engines have to be more solidly designed due the the greater vibration from non-ideal crank throws.
So, the 180 triple was a big-bang engine, in some cases a very big bang (sorry Yogi, couldn't resist ).
