I have been thinking about this (dangerous, I know :-* )......
Like Robjota, I think the triple 180 engine is some way to being a big bang configuration, given the gap in the firing of the cylinders.
In the past, I heard the Laverda 180 triple described as a 4 cylinder engine with one cylinder cut off. This never made sense to me, as a normal 4 cyl. engine has outer pair and inner pair of pistons at 180 degrees to each other......so the cylinder that the Laverda triple is missing is number 2 or number 3.
So, the 180 triple is a flat plane, albeit a modified one that seems for be a version of the big bang engine.
Given that a flat plane crank has pistons at 180 degrees to each other and a cross plane has cylinders at 90 degrees to each other, I wonder how a cross plane triple would be configured? 1st cylinder at -90 degrees, centre at +180 degrees (or zero degrees) and 3rd cylinder at +90 degrees?
Maybe that's what Yamaha are doing (dunno)
Tried to work out how it would fire - but seemed very strange (fire centre, rotate 90 degrees fire left, rotate 180 degrees fire right, rotate 450 degrees fire left again etc etc.)
That 450 degrees is a BIG gap....
I think the Laverda 180 is: Fire left, rotate 180 degrees fire centre, rotate 180 degrees fire right, rotate 360 degrees fire left again etc. etc.
.......now my head hurts (help)
Pete
