Correct Cam,
It is oil-soluble, with very little to no excess to be found in engines that for some reason have to be opened again. Does afford peace of mind, compared to silicon-based sealants!
A thin bead will result in thicknesses of less than 0.02mm If applied liberally, as in applied with a brush, thickness can be as much as 0.2mm! This stuff will not flow readily under pressure, the more you apply, the more will remain in the joint. As in my photo, the sealant will only just appear externally when the cases are buttoned up, hardly anything needs to be wiped off. Of course, this does mean the joint surfaces need to be in perfect condition. I prepare them with a fine oil stone to keep them flat and square. Loctite offers other products that are suitable for reclaiming buggered sealing joints.
I haven't had any issues with Loctite products that have reached their use-by date. Some do seperate from their solvents and require a bit of kneading before squeezing from their container (518 e.g), haven't noticed this with 510 (probably because it's in constant use and doesn't get that old...).
Bloody expensive stuff, I buy it in bulk 500gr. tubes, which is loads cheaper than the workshop sized 50gr. bottles.
Another very handy Loctite product is 572, used as a thread sealant on oil plugs, etc. Just saw Clem has already mentioned it...
No, I don't have any Henkel/Loctite shares... just bloody good products that can be unconditionally recommended!
