Laverdalothar
- Germany
Chain clearance to the tire and the rear shocks as well as chain-wheel clearance to the swing-arm are the issues, everything else should be wide enough for a 180.No. The layout of the box with a direct top on the side opposite the clutch is almost unique today. If you used a Japanese - or practically any other modern box - the final drive would come off the layshaft. Which raises problems of sprocket height and position vs the swingarm.
Red - a 180 will fit on a 5in rim as has been said before. I'd suspect that tyre clearance is your problem rather than rim. A coarse file can be used on the extreme edges of the tyre...Can gain you around 5mm.
To solve this, you could extend the main-gear shaft and have a counter-support with a bearing in an extended clutch/shifter cover to move the sprocket out 10mm. In that case, I suppose a wider swing-arm is necessary, else you might get in trouble with the chain-wheel and potentially the shocks, too (assumed you ride a twin-shock bike). In that case, a change to a central single shock would be the way.
But what do I know - Red has million times more experience and know-how than me, pretty sure he'll come up with a fantastic solution!
