piranha-bro2
- Melbourne
And happy birthday, Oehlin!
The ball inside is 6,5 mm and the one in the cover is 8mm according to Laverda ParadiseClutch pushrod ball is 1/4 inch - been discussed on here before (recently). And I'm almost positive the one in the cover is 1/4 inch also - 8mm sounds very odd to me, but happy to be corrected. Not at home (at a beach house) so can't check.
Piet?!!
3/16" and 5/16" from memory. Couldn't be arsed to check a manual atm...Clutch pushrod ball is 1/4 inch - been discussed on here before (recently). And I'm almost positive the one in the cover is 1/4 inch also - 8mm sounds very odd to me, but happy to be corrected. Not at home (at a beach house) so can't check.
Piet?!!
That's it - memory's fukt! 1/4 inch it seems it definitely is not!3/16" and 5/16" from memory. Couldn't be arsed to check a manual atm...
Mainshaft bore is only 6.xx mm, 1/4" will be a tight fit and could jam, 6mm would be OK. Ball in actuator definitely larger, closer to 8mm.
We had already clarified the issue with the balls several times in the forum. The information you quoted from Wagner is correct.The ball inside is 6,5 mm and the one in the cover is 8mm according to Laverda Paradise
If the inside of the mainshaft is 6mm as Piet mentions, a 6.5mm ball will not fit. 3/16 = 4.7625mm, 1/4 = 6.35mm. I'll make my own measurements when i get the chance.We had already clarified the issue with the balls several times in the forum. The information you quoted from Wagner is correct.
Ball between clutch thrust rod Ø 6.5mm-> clutch rod inside gearbox gear 750 112.5mm -> Ball on clutch thrust rod Ø 8mm"
What you see is what you get -> I have just measured five different 750 main shafts.If the inside of the mainshaft is 6mm as Piet mentions, a 6.5mm ball will not fit.
.... apparently we have no other real problems ....Some of us seem to be suffering from short term memory loss...or the after effects of heavy New Year celebrations?
https://laverdaforum.com/xf/threads/102063/post-485566
Mainshaft measurement 1
Mainshaft measurement 2
Mainshaft measurement 3Sadly a limitation of the MySQL database minimum word length. There is a solution but it requires business spec hosting at GBP99 per monthBy the way - I find it problematic that you cannot search for short words (<4 letters) in the search function.
Perfect tool, but at almost $ 1,000 too expensive for home use.attached photos show actual internal measurements ....
Thomas, When I saw Red's pic, I thought; "what a great tool/toy." Thank you for bringing me back to earth.Perfect tool, but at almost $ 1,000 too expensive for home use.
Your measurement result explains, why a 6.5mm ball falls completely through the (clean) bore of the shaft.
Unfortunately, your company is so far away from Germany. If transport and customs were cheaper, I would have a lot of work for you ......
Thomas aus LAU
