Unfiltered Intake Air.
Did a reno on a local club years ago, we pulled a large toaster out and deep inside was a large rat skeleton. Who knows how long that had been marinating there.
My favourite story along those lines comes from when a bunch of us were renovating a Kentucky fried chicken (before it was called KFC, so a long time ago). We were all standing on saw stools and ladders holding up the huge chip hood while one bloke in the ceiling was undoing the bolts. Dozens of cockroaches were crawling up the inside of the hood out of the grease gutter, then falling off the slippery surface, straight down where the fryers used to be.
Ever since that, I’ve always had a really close look at the little crispy bits at the bottom of a bag of chips 😬
Hi Red, I would be very interested in a link to the velocity stack article. The Austin 7 hasn't raced in anger for 22 years, but is about to go on loan to another forum member to harrass a small rural NSW community, similar to its holiday in Murwillumbah last year. The guy that used to beat me down the straight at eastern creek had de- siamesed the 2 inlet ports and installed 4 amal carbys, with ram tubes and velocity stacks.
Try this:
Well done Baz. That's the most comprehensive article on the topic of bellmouths that I'm aware of. Should answer every question you ever dreamed of Marty!
The late Professor Gordon Blair (author of article) is well known in engineering circles for his work on fluid dynamics in general, and its application to internal combustion engines in particular. He was a keen supporter of motorcycle racing did a lot of work on 2-stroke induction and scavenging in the late 1960's. His engines would beat the factory race bikes and he ended up working with Yamaha to design their TZ range of 2-stroke race engines.
BTW, if you're going to fit bellmouths to improve performance, don't put wire mesh strainers on them. If you do, you may as well just use a bean can as an inlet trumpet because the wire mesh will totally screw up the air flow.
I suppose I could read the entire article but I'll be honest and admit I'm not sure or grasp what the author is saying, I did understand his conclusion.
CONCLUSIONS While the specific conclusions have already been highlighted at each stage of the discussion above, the general conclusion might be glibly stated that the design of an intake bellmouth is not as difficult nor as vital to good engine breathing as might have been imagined. On the other hand, in racing, where the last few hp per 100 hp is the difference between winning and losing, the design exemplars discussed above are not to be lightly ignored
My next question is when looking for improved top speed, would these be an asset?
No idea, but hell yer. Get a good number for the team. Maybe Dino time before, do some reading as to gearing, apparently, there is a lot of drag. It's not so easy to do good. Lake Gardener in SA is following its name the year, well well wet.
Hoping to take a run on the salt flats in Utah (Bonneville) this year,' Run What ya brung' it's on the bucket list, still.
I thought velocity stacks were all about top speed performance, comments are appreciated.
Velocity stacks maximise power, dependent on their length, at a certain RPM, as do megaphones.
Not necessarily an aid to maximum speed.
I suppose if you had read the entire article you would have read “The best bellmouths are those that are short and fat with the elliptical the winner”.
That doesn't mean I know anything but those bellmouths in the ebay link are "long".
Jim
Jim
So these Sudco ones fitted to my FCRs should do the trick (with large intake tubes linking to two very large air filters) ...
Jim
They also don't have the full wrap-around lip on the entry as recommended by Prof Blair. I suspect the primary design criteria for those inlets was that they should look cool.
