not certain on the PTFE coating question, looking at a couple of options right nowIf you are going to make heavy duty tensioners to combat breakage and are just worried about how to adhere the rubber lining to the blade , would it be possible to forget the lining and have the blades PTFE Teflon coated instead (or something similar) ?
With a race engine a top end inspection at regular intervals would keep an eye on how things are getting on.
I take it that it`s the tensioned blade at the rear that is breaking up , not the static one at the front. ( Yes I see it is).
Makes me wonder if it would be possible to junk the tensioner blade altogether . Whenever I fitted a new (Regina) camchain , play between the sprockets was always on the tight side if anything , so the tensioner never came into play , the adjuster bolt just tightened enough so the roller just made contact with the blade and no more.
I know the blade acts as a guide as well as a tensioner , and the distance between cam and crank sprockets would produce more chain free play than between the two cam sprockets at the top and cause fluctuation with no blade to dampen it down , but wonder if a new camchain fitted each time the engine is used in anger would keep this to a minimum , providing there is enough clearance within the camchain tunnel to accommodate this extra movement .
Actually thinking about it again , with a final drive chain under load , the top run between gearbox and rear wheel sprockets is kept in tension , whilst the lower run is going to fluctuate , so with the camchain run at the front between the crank sprocket and cam sprocket being the one under load , then the run at the rear is most likely to suffer near terminal fluctuation with no blade fitted , so maybe not such a good idea after all .
we service both race engines after every meeting, check shim clearance, check head torque, change oil, change gearing for next track, fix any other issues that have appeared over the weekend, fire them up and check carb balance, etc
constantly working on them
not possible to junk the blade, what you see on your engine with a standard thickness cylinder head and barrel is far from what we have in play now, running these engines they way we do with the horsepower we are making we have an issue with cylinder heads warping, is an ongoing issue so what we find is that every season we race the compression ratio rises as we have to keep skimming the cylinder head to get them to seal
That means two things, one we have loose cam chain runs due to decreasing dimensional issues which we counter to a point with offset billet cam blocks and thicker head and base gaskets but on the Mule for example she is down that far now that we are at 13.8:1 CR currently and still have a loose cam chain run so need that blade in play
