Tippie
- Dr?bak, Norway
Most likely the shafts have side shimming for end float which is critical and should be in spec, removing the gasket will reduce end float. Also a gasket is much better at filling gaps. It sounds like it was a good call to open it up with what you found. Ever more hours going into that little monster. Hopefully it is a fun ride and completes the rally.
