Overhaul Blog, 1968 750 GT
Exhaust gaskets not sealing at all, sucking oil down the guides.
The top engine bolts don't line up. DPO has elongated the holes in the frame. OMG.
Frame may well not be precise, I wouldn't be surprised. I always put engine in the frame top mounts first and sometimes, the rear needs a bit of leverage.
Heaps too much feeplay side to side in the tappets, so multiple head issues. The "restorer" back in the US seems to have had a dislike of washers, nuts and bolts assembled everywhere have bitten into and damaged the alloy. The rear brake arm worries me deeply.
How much side float, have you measured it ? I’m doing my ‘69 GT simultaneously, side float is pretty constant .20mm ( if you remember I’m trying to trace that odd 4000rpm rattle we spoke about..)
I’ve seen elongated frame mounts due to lose bolts, any way very interested in the rebuild!
One of the XT500 Yamahas I owned had hugely egg-shaped swingarm mount holes, they must get loose and continue to be flogged to death. Poor old bikes run till they drop. My bodgy fix back then was renewing the bearings and welding nice thick washers to the frame. Better than junking it. It stopped a lot of weaving.
If in need, I may have one of those brake stays but probably simpler just to weld the hole up.
Head off. Cam chain fitted without the centre plate in the joining link. Rh ex tappet is later type. Side clearances as follows.
Ex. 0.52mm. 0.38mm
In. 0.23mm. 0.50mm
