AJ
- 38°33'00.0"S 177°55'00"E
The only issue I had was a 6.35mm wide sprocket was machining a groove in the output shaft much faster than a 9.5mm wide sprocket would. I have no problems with the 520 apart from that. As you say if the DPO had machined the sprocket at the chain circumference (as they did on the wheel sprocket) then it would not have made any difference.
Plate sprockets will be readily available at an engineering supply company and a machine shop will bore and drill it to the original specs.
