Some may remember that I was knocked off my 3C on March 17th last. I suffered a dislocated thumb and a broken heel which are still giving me trouble. The bike with a full tank of petrol caught fire and burnt.
The car driver having admitted his entire responsibility in the accident, my insurer paid out the agreed value of the machine which should cover a rebuild. I could have bought another nice one with that money, but this 3C was mine and I had the sweet taste of revenge in my mouth. I'd also had the engine extensively rebuilt by Keith Nairn with 78mm pistons needing new liners and the cases opened out, a rebuilt crank with Arrow rods and dynamic balancing.
I took bits off the bike over the last couple of months, all the while buying parts to rebuild it, convinced that it was rebuildable. Call it faith.
I had a couple of down moments. First, when taking the oil cooler fittings from the crankcase, a bit of water came out. There was also some water under the starter freewheel and in the primary case. The fire was doused by the firemen when they arrived and the bike was stood a week outdoors waiting for the insurance expert to come, before we could bring it home. No rust to be seen on the steel bits, notably the bearings. The synthetic cage on the left hand layshaft bearing has suffered from the heat. The engine can be turned over by hand, albeit with a bit of initial difficulty.
The clutch discs were well and truly stuck together. It was whilst trying the bike after having taken off the DAM kit because of a sticking clutch, suspecting insufficient lift, that I was hit.
I've been going from a half full to a half empty morale situation regularly with this project.
The more exposed and thin alloy parts have suffered, cam cover and sprocket cover, but not the main castings.
The final decision on whether to rebuild it or move on would need opening the engine. Yesterday, a big step was taken when my son Matthieu dropped in for tea and to give a hand taking the engine out. An overhead winch in the garage is a big help with these lumps.
The mixture of burnt oil and rubber clings to everything. Some people love black engines.
As soon as the engine was out, I whipped off the cam cover. I was relieved to find that all was okay. Just some cooked oil and molten rubber.
I'll open this engine next week for a final diagnosis. I expect to find some water in the bores, we'll see.
