piranha-bro2
- Melbourne
Converted my custom Gates tooth-belt driven alternator on the SFQ to Gates Micro-V. A lot trickier than I anticipated with limited 'leg room' for pulley sizes, ratios and belt length. Dropped drive ratio from 1.75:1 to 1.6:1. The first incarnation used a narrower toothed belt, which broke after 6 months, so fitted a stronger, wider one. That lasted several years and many thousands of km but broke very soon after getting the Q on the road. The replacement lasted 800km before it stripped all its teeth (pic). How long would the second new one have lasted? Can't trust it. Possibly the wrong application for it here, but confused as to why the new ones don't seem to be coing when I had such a good run with the wider belt after I fitted it.
Gone for what I hope is a better alternative. It's possible the toothed belt doesn't like the high RPM I'm dishing out (but that's nothing new to my previous SF/C) or else Gates' quality control has dropped. Many hours toil on the little Emco lathe.
While I was at it, I drilled 'escape' holes into my second starter clutch - for removing stuck pins - and reconfigured my shift lever mech - shorter rod, closer to parallel angles and hopefully higher, so I can get my new boot under the lever without suffering a cramp! Phillip Island track day coming up and do NOT want to be thinking about how to shift down!
