Tippie
- Dr?bak, Norway
The max advance "A" mark on an SF is 40 degrees, which is a lot, and many bikes are prone to pinking under load depending on fuel and other tuning issues. Static timing is set at PM (top dead centre), and using these marks accurately it is best to mount a pointer of some sort close to the mark. It is some distance to the mark on the crank case from the starter clutch, and regardless, check the accuracy of the PM mark against the piston at TDC. If you set static timing to 5 deg BTDC then the full advance is 45. It is possible also to reduce the range of advance in the centrifugal unit with a dab of weld if you want less max advance. The thickness of material on the contacts in your picture seems fine, the surface needs to be as perfect and flat as possible, can be achieved with a fine sharpening stone with the points dismantled. I think the platinum contact pads are somehow soldered (or similar) onto the backing metal, not riveted.
