Re5Guy
- New Zealand
Hello all, I have been trying to get my RGS Corsa to run properly since it's first start in 30? years last month. I cannot get it to run properly at low revs. It goes fine as the revs increase, but it feels very rough and unhappy down low. I strongly suspect the carbs.
I have read and checked many suggestions on this forum and tried anything that seemed related, but in short....
- valve clearances are correct
- carbs stripped, ultra sound cleaned and new everything installed and set to std spec. It is running std jets, 65 pilot and 118 mains.
- Float levels carefully checked and rechecked
- chokes are fully off
- needle valves seating properly
- no air leaks evident.
-DMC/32 ignition fitted and new plugs. They are black and sooty looking if it has been idling, but look much better after a quick blat round the block.
-it starts very easily
There is a big clue which I don't understand the significance of though and I thought I would ask here. Adjusting the air/fuel screws makes no difference at all to the engine idle. At 1.5 turns out it runs exactly the same as 3 turns or 1 turn for all three.
Hopefully this will mean something?
cheers,
Tony
cheers,
Tony
