Tippie
- Dr?bak, Norway
Agree with you John, it is not just the spark plug causing the problem. Back then SF2 and 3 came to Australia jetted very lean, 40 pilots that had them really hard to get a good idle, and 140 mains that were too lean, at least for full throttle on that long hill heavily loaded. Not many bikes were subjected to that back then, although SF generally have been known to like holed pistons, (which is not as horrific as the triples taste for busted rods). Subsequent swap to 45 and 145 and it was fine, living in Darwin with no open road speed limit, lots of flat out riding without a problem. I did a race meeting a few years ago and took advice from a top tuner here who said to use the hottest plug you can get away with, so swapped the 9s for 8s and had no problem at all, as the bike was jetted and everything else set up correctly. Next meeting I got the heebie jeebies and went back to the colder plugs though.
Those Bosch GT40 coils had a bad reputation back in the day, fortunately there was rarely a need to replace the original coils from the factory.
There was much discussion previously here about plug chops being useless indicators with modern/lead free fuels. Is that still the case?
