rocketonarail
- Gloucestershire,England
Just an update everyone, I've been away for the last 2 months plus so just back into it now...
I have changed the pilots to 55s, replaced the choke plungers and the pesky short spring mentioned earlier. It is now better but still definitely not right.
I can now get some change in engine speed playing with the fuel mixture screws but the bike is still rough between idle and 2,000rpm.
It will now pop and backfire on the over run when slowing down (which it didn't do before the changes above) and it just feels unhappy. Get to 2,000rpm and all is well.
I have looked for air leaks where ever I can think to look and tightened everything up. The only thing I haven't done yet is remove the inlet manifolds and double check them for any cracks/leaks...hopefully this weekend.
It still starts and idles well after it's warmed up.
This is all part of the "FUN"...right?![]()
If you can keep a RE5 on the road , then I`m sure you`ll get the RGS sorted eventually .........
