That's because lawn mowers, like a lot of things need to be mass produced and sold to even the dumbest.The fault though is rarely the ignition system itself, mostly incorrect wiring or assembly... user faults.
I've had to rectify many DIY installations of the Witt DMC because the owners/installers were too lazy to read the manual or simply thought they knew better, which is more often the case than one would assume! Bike electrics follow simple rules, ignore them and reliability issues are sure to follow.
Undeniable facts are that electronic systems offer maintenance-free operation and very often, enhanced engine performance.
There really is a reason why even the most humble lawn mower engines use electronic, breaker points-less systems these days.
You're not alone on this forum.Really? Once I got my Ignitech set up I have total confidence that it will give me trouble free motoring. And the custom setup I had for decades using a Suzuki ND system rigged to the Bosch advance unit was also 100% reliable. I've also fitted that system to other SFs. Do I miss the points?
Will you use it a lot?My SFC will never run on points again after this re-commission!!
Seems todays small internal combustion aero engines still use magnetos as the primary ignition choice, but breaker points have been largely phased out. CDI systems, basically like that originally used in Lav triples, seem to be quite common, but doubled up to comply with aviation regulations. Fully digital motor management systems are also in widespread use.Dual Mags for redundancy?
Would the lack of air traffic reflect the local economy? General Aviation is quite expensive and vacations can be too, even with a cheap air ticket.if they did it in light aviation, as Piet says, it must be a good thing, because the rule in light aviation is that of never wanting to change something that works, until very recently their was a lot of light aviation coming out of Biggin Hill, many 30 or even 40 year old Cesnna's etc its barely 3 miles from here as the crow flies, during and since Covid that has basically stopped, the most aeroplanes that I see overhead of my house are now single or two seat Spitfires, with a Cessna spotter plane (sometimes) and thats about it, In the cafe at the airfield you could not see accross the apron for parked light aircraft, now there are just, maybe, five, instead of lterally dozens, where did they all go? magnetos included, its the same with commercial aviation, before Covid at 7 am when the main airports fully open, (Heathrow is only allowed 8 flights per night) the sky (on a still day) was like a patchwork quilt, now at 0700 to 0730, you see two, maye three, we all know where those planes are tho, in Gloucester, you cant get another Jumbo on the ground because there is no space left!
I set up a basic curve, Vince and have really not had to change it much - I had greenhorn (me) issues initially getting my head around base advance and not being able to correct a discrepancy between left and right, but the curve is nothing special - the motor just has a big fat torque curve with no dips at all from 3500-8000 but a couple of noticeable 'up' ramps as the cam and pipe come into play. On the dyno we found an extra 3hp by upping max advance from 32 to 35 degrees. Other than that I haven't felt the need to change it.Has anyone developed an Ignitech Ignition Curve for twins yet? Q? Mine was done on a club ride to the Bylong Valley much to the unhappy faces waiting at various stops while Brett attached his Laptop and asked me how the change was ever 50ks or so. It was surprising to feel the effects.
QuestionI would stick with points ( points didn’t cause your piston to hole) because you already have them, just plonk a new set on ( VW points with pin removed ) set them up with a strobe and your away. I have original 1969 points, new coils ( VW) and new condensers - starts instantly, runs fine- ideal. Holed piston could well be weak mixture ..
Points will be the last cause of a misfire unless they're dirty.Question
Need points for my 750 SF 1971 model, what VW model or part number did you refer to in your reply.
I have a left cylinder mis firing so it's new coils and points to see if that cures the issue.
I took a set to a USA auto parts store and looked at 1969 VW Bug points but they have a different
mount hole for the screw location. Any recommendations would be a great help.
Thanks guys
Jeff USA California
You have to modify VW points by drilling out pivot pin. Coils VW , condensers I got from eBay , pretty much any set of condensers that will fit will be fine ( could ft them externally also) and new caps & leads. I had a misfire from the points, nut and bolt through flag was slightly lose, I mean 1/4 turn. Take them all apart and clean off all corrosion - your relying on tiny contact patches for current to flow.Question
Thanks guys
Jeff USA California
