R
Reggie3cl
Guest
The season is drawing to a close and I am off to France on the old Beemer in November
Nice. I did that a few times in the past and you can get some great weather and clear roads.
redax5 said:I normally bolt a small plate onto the side of the electrical box where the Bosch black box was and then stick the Sachse box onto the plate
is just behind the side cover that way and easy to get to if you wish to change curves
jotajoe said:Thanks Davo.
Didi you fit yours to the 3CL btw ? ..as against mine is a 180 series 1 Jota
joe
Yep. What red says. Connect the spare HT lead on the centre coil to an earth somewhere. Closest point available would probably be one of the coil mounting bolts. That's how my Jota is wired. It's the way it came when I bought it. It had a Witt ignition back in those days with what I assume are a pair of twin output coils recovered from a 4-cylinder Japanese bike. It's always worked OK so I never bothered changing it, even after fitting an Ignitech ignition.
For some OCD related reason it's occasionally bothered me when I lift the tank off to see a dual coil "wasted" in that way to fire a single plug and I've occasionally thought about swapping it for a single outlet coil (especially since I have a couple in a box of electrical junk). But John makes a good point in his comment above about separation of primary and secondary circuits and the interchangeability of coils, so I'm better off leaving as it is. He's cured my OCD!
Well as they say “every days a school day”I would never have thought you could do that.This is on a 180 with IIS ignition and Dyna 3 ohm dual output coils. The front coil has one coil output connected to ground at the bottom of the coil.View attachment 101678
Just keep your ghoolies away from the frame when the engine is running.absolutely magic guys , much appreciated - will earth the 2nd coil post to the frame coil mounting points![]()
Why not take @redax5 opinion & ditch the mini coils & get recommended coils? BTW I run a Redax/Sachse system on my '76 3CL.absolutely magic guys , much appreciated - will earth the 2nd coil post to the frame coil mounting points![]()
That's a good piece of information. Nology coils fit easily in the space formerly occupied by the CDI. Who'd have thought OEM parts would be less?Use the coils from modern Triumphs.
Same as the excellent Noology but half price.
