BEARS Australia 2026
Any race reports ... or timing sites I can visit?
In Vanuatu for a cuppla weeks - I've taken on the chill factor and the brains in slo-mo. Mr Muir posted that the van was loaded and ready to head off last Wednesday
left home Thursday morning, stopped overnight at Mitchell, Winton, Barkly Homestead and Pine Creek
Arrived at the track 08:35 Monday morning, total 3,410 klms
Weather is perfect 👌
This is our first time back to Hidden Valley for 3 years or maybe 4, not certain
Be interesting to see how the bikes go, last time we were here had 160 rear slicks and no Slipper Clutch
Now we have 180 rear slicks, both engines with rebuilt gearboxes and Slipper Clutches
Looking forward to the weeks practice and racing on the weekend, should lower our lap record here, all going well
Hi Red, all the best to you and your team!
Ciao, Gert
Tuesday morning, scrutineering done on all 3 bikes, passed easily
Ready for 4 days of practice
Between Matt's BMW and the Laverda's we have 8 brand new rear slicks and 6 new front slicks
Planning on doing a few laps
Sounds like all is ready for a great week Red..
Have at it eh..(y)
:cool:
3 or 4 years since you have been there; how did that happen? Why do I think it's an annual trip? My memory definitely is broken.
Been an interesting week so far
Passed scrutineering Tuesday morning okay, Matt took the BMW out for our 1st session, no issues
Mule next for her first run and on the 4th lap decided did not like being in 5th gear any more
Once cooled down dropped Exhaust and Belly Pan so we could access the Eccentric, made a slight adjustment but next time out no difference so when back in we dropped rear sprocket down to a 39 from 40 tooth
Took Veloce out but she was pumping too much in the rear so we swapped rear shocks from the Mule to Veloce as her preload adjuster is not playing the game
Wednesday, took Mule out first to try just 4 gears, she pulled a top speed of 222klms, not bad for 4th
Veloce with a 40 tooth sprocket and 5 gears only pulled 228klms on the straight
only did one more session on Veloce and one on the BMW but half way down the main straight the throttle tube on the BMW snapped off at the Fly by Wire assembly so now no throttle
Found one of the other BMW racers had a spare assembly but on installing it we could not program the ECU to learn the new Throttle assy even though was an exact same unit
Could not clear the existing error codes
Thursday, Brett arrived from Sydney on his 1200 Wednesday night being a 4,150 klm ride so both of us in the pits now
we had loaded the BMW in the race van and Matt and Brett were at the BMW Darwin dealer when they opened at 8am
After an hour or so, success, error codes cleared, reloaded the race map and back to the track
One session on Veloce in the morning and Matt decided we needed to change the rear spring rate so both shocks out, found a shockie spring compressor in the pits, changed both springs fronm 80 to 85 rate
Then reset the sag on Veloce and did the best we could with the Mules rear shock with a non working preload
Few more sessions, couple of tyre changes on Veloce and the BM, went home
Friday morning, Veloce qualified 2nd on the grid behind a KTM F3 bike, we being F4
Matt put the BMW in 4th in F1
First race, Veloce home 2nd outright behind the KTM, 1st in F4 class
Ran 1min, 15.5, only 0.2 seconds off of our lap record
Been a busy week, was expecting to just be bored all week but been working on all three all week
Two days left, 3 races eithe of the Laverda's and 3 on the BMW though may take the BMW out in the Superbike feature race
Going for a drink
Racing - the fickle beast. As you say, a quiet week turns into a grinder. At least you've had results - top effort considering.
What size rear sprocket and what RPM to get El Mule to 228 in 4th?!
39 tooth, no idea of rpm, Tacho's are unnecessary weight and a distraction to the rider
We only run a lap timer which gives us lap times, top speed, G-force etc at the end of the race and flashes lap times across the finish line each lap
Our Tacho is two lights, yellow light starts to flash at 9,000 rpm, goes solid light at 9,250 rpm
Red light beside it starts to flash at 9,250 rpm, goes solid at 9,500 rpm
Rev limiter is currently set at 9,800 rpm.
All programmed in the Ignitech
Race 2, have to use Mule with only 4 gears, Veloce engine not good now, starting to smoke slightly and sounds off
2nd outright, 1st in class, lowered our Lap record by 0.001 secs
Fucking awesome 👌
If she had 5th we would be 1 second under at least and fighting the KTM for outright 1st
Top speed in 4th 225 klms, yellow light flashing so at least 9,000 rpm
3rd race, same result, Mule 2nd outright, 1st in Class
Getting hot now, 34C, track temp up to 62C so tyres starting to slide around
Ran a 16.0 sec flat but front tyre now past its useful life
BMW first race after lunch and we are done for the day
Apart from changing more wheels 🛞
This morning during BMW first race Steering Dampener failed so before next outing we took the one off of Veloce, fitted straight on with only minor adjustment
One race left tomorrow and start packing for the drive home
