Not so good Nadia, the lack of knowledge at local shop, at least you have a point of reference for the issues. Your description prior did have elements of overfilled oil change, hence the question of what was performed or changed since last time the engine ran correctly.Nope they are not remotely exciting and I can say that with a minuscule amount of authority.
The upshot of my smoking engine: sadly the last service, which was done by a local service centre team, must not have realised that the engine had to be warm to top off the oil and filled her with 4lts of oilthe hot oil, as I understand, has apparently been seeping out burning bits and bobs. Apparently that and the wiring that was damaged has now been repaired.
For what it is worth have seen over filled Laverda motors as well, can inflict variable degrees of motor damage, most though can be rectified, ie no bent metal parts as in the case of fuel hydraulic lock. Refer to the famous "Bent Conrod Award" for Laverda NSW club, wonder if that trophy is in circulation? A tribute to the famous/infamous Mr Paul Trillo, much missed, in no small measure.
Trust the bill is not breathtaking, for the repairs, can add up. j.
