I don’t think it (smoke) was coming from the exhaust more from below the tank and mainly (R) side when viewed from riding position. Mind you the fuel tank is actually under the seat in this model
N
Oh. That's an entirely different thing to smoke from the exhaust. You did actually say in your initial post on the subject that the smoke was coming from the
engine (not the exhaust). Apologies for the misunderstanding. Ignore previous advice to start the bike and see if exhaust smoke clears.
I also recall you described it as having an acrid smell like hot rubber. That sounds very much like the insulation on some part of the bike's wiring has been cooked. Most wiring is protected by fuses so excessive current caused by a fault (eg. a short circuit) will normally just blow a fuse rather than cook the wiring harness. But high resistance at a connection somewhere can cause excessive heat and cook insulation without the fuse blowing. A small bit of burnt plastic can produce a lot of smoke.
The starter motor cables are not fuse protected though, so if you were cranking the engine for a long time, the electrical cables to the starter motor could have overheated. If the insulation is damaged and shorting against the frame somewhere, it could be a fire hazard, so you really need to check it out before trying to start the bike again.
Bearing in mind your self-confessed lack of technical expertise, this sounds like a job for someone with knowledge of vehicle electrics. But you can do some visual checks yourself. If the cable to the starter motor is visible, have a look to see if the plastic insulation appears to have been heat damaged.
If the starter cable looks OK, take off the tank and seat (or whatever covers the working parts of the bike) and check for burnt or melted insulation on wires where they enter/leave the wiring harness. Also check the cables where they connect to the battery. Excessive resistance at the battery terminal connections can also cause overheating, especially while cranking the starter motor.
Hopefully it's something easily fixed like a poor connection or a heat stressed starter cable, and not a completely melted wiring harness.
