TeddyG
- Portland Oregon
Update on my oil saga:
For the 300 mile break in I used 20 50 Motul Mineral oil which I have changed twice, and each time there was some minor swirl. During assembly I coated the cylinders w oil and applied red line assembly lube on the cams. A boroscope shows that the cross hatching from the honing is still present, and I had the bores rechecked that showed trueness. At @ 150 miles compression was @ 145lbs, and at 300 miles it’s @170 lbs, which is good news. I’ve been varying the speeds without red lining, constantly doing 40-65 mph, and sometimes 70 mph. This is the second time around with Ross pistons and the motor feels smoother at 60 mph than before. I’ll use 20 50 Motul full synthetic next and re torque the cylinder head nuts. I’m hoping the combination of a slightly looser bore ( to allow for the forged piston expansion), Teflon coated pistons, and using full synthetic will be the fix since I didn’t want to split the cases to examine the slingers which may or may not be the problem. Again, the oil analysis of the Bell Ray mineral oil I previously used indicated that it lost viscosity, and was told to use synthetic oil after the break in. Oil has improved since 1974.
I appreciate all the helpful input.
