michipons
- Palma de Mallorca
Hi Steve,Hi @Laverdalothar ,
The kit I used was part number 2100309 to suit 2010-16 Kawa Z1000. Here's one:
The hose length was fine for my Jota with Renthal 'flat' one piece bars, I expect it would also be fine for stock jota bars for anyone unfortunate enough to still use those.![]()
Magura 2100309 Hymec Hydraulic Clutch Conversion System | eBay
Find many great new & used options and get the best deals for Magura 2100309 Hymec Hydraulic Clutch Conversion System at the best online prices at eBay!www.ebay.com.auReally high bars might require a longer hose, perhaps there is a suitable alternative kit. Note the lever comes in silver or black, silver looks better on the old clunkers, so be sure any alternative number you get has the silver lever.
I copied the esteemed @CJMAC who trod this path before me with his SF2. He initially fitted it with the DAM extended lever and the operation was TOO LIGHT and was unbalanced with the other controls. A return to the stock release lever makes it perfect.
As mentioned, it comes pre-bled and does not require disassembly of that to fit.
The only slight modification I made was the adapter sleeve shown here:
The shiny silver bit is a separate tophat shaped piece to adapt the slave cylinder to various bikes. The hole in the Laverda crankcase is M8x1.0, so the through diameter is~7mm. The sleeve that came with the kit is 8mm outside diameter, so I turned it down to 7mm. It's a bit iffy because the inside diameter of that sleeve is 6mm from memory, so only 0.5mm wall thickness. In reality, all it does is centralise the slave cylinder and hold it a bit more securely, you could probably do without it altogether. Maybe then the stroke might not quite work, in which case put a few 8mm washers over it to match the thickness of the step in the tophat piece. The best option might be an M8x1.0 bolt drilled to 6mm thru and the head turned down to just a couple of mm thick like the adapter sleeve, but it's really not necessary. The cylinder is stabilised by the internal spring which exerts a slight pressure on the release system.
It's a brilliant bit of kit that just works, is easy to fit, requires no mods to the bike, is mineral oil based so does not absorb water, is away from the front sprocket so does not absorb chain grease and dirt into the hydraulics.
The kit is perhaps a bit pricey, but it's probably competitive or cheaper than the alternatives and retains the look of the original cover.
Can you tell I like it?
SteveB
(Post edited to correct diameters above)
I have one question, how do you do with this set the fine adjustment? I assume that just like the real cable, you need to adjust the rod so that in “relax” position, it just touches the clutch lever, so that the cylinder has enough travel to actually clutch, doe this cylinder come with this possibility?
I am seriously thinking to buy one, and a redax one, one for each bike
I barely ride my 750 because of the clutch strength, i don't like to admit it but this is the reason why is always the last on my garage line.. and I don’t want to have the 1200 in the same situation. My 1000 has standard cable and works beautiful, it is just a little softer but below my limit.
@breganzane trying to find one set to buy in Europe I saw there are like hundreds of sizes… I guess it has to be the one you bought? Or are other references that would work? The ref. of yours is 2100309
Best regards,
Miguel
