Good pic Steve, well worth a look, but not in today's 40c heat. I well remember Christian letting us do an Ignition bypass hotwire job at your place on my bike, heading home from a Tassie trip, after we later discovered that my main ignition earth wire had stretched and snapped 50mm up under the insulation, when my battery strap had snapped after a small tipover. I guess if you do the ks, shit happens and breaks. I think this is the 4th or 5th oddball ignition issue in the last 35 years with Boshe, Wilson, and now Ingatch Ignitions. So I have had nuts come off connections, keyed switches fail internally, wires break, batteries lose cells, wires get cut on Altinators, coils lose earths, plugs fail, the best example of a plug fail was having a chunk of piston brake off and hit the spark plug and close its gap, would you class that as an electrical fault? I think that's the lot over the years.
