chrisk
- Brisbane, Australia
If you're paying Chris in beer, he'll be an alcoholic by the time your panniers and crash bars are finished.![]()
Too late, seen the old fella down a pint?
I think you can get to the battery without too much grief Vince, here’s a photo of my other MK2 Atlas.Well I managed to patch that 20mm oval hole in the airbox, I used a Coke Can and some Automotive Sika Body fixing glue, I will add some Waterproof Gorilla Tape after it drys. I would have liked to remove the airbox to do this and give it a througher clean BUT to get it out you need to remove the battery and to remove the battery it looks very much like the exhaust needs to come off and that's a 2-day nightmare I don't need right now, BTW the insanely stupid airbox design has curved and recessed corners and impossible to get a finger on the inside roof and said corners that are impossible to clean insitue. It got flooded with contact cleaner and paper towels so hopefully that's good enough. This is by far the hardest bike to do maintenance on I ever worked on. I would hate to have to replace the battery if as I suspect the exhaust needs pulling to do that.
That's an unsafe way to do it mate. Drinking Coke will rot your teeth.Well I managed to patch that 20mm oval hole in the airbox, I used a Coke Can and some Automotive Sika Body fixing glue ...
Yes. It is the old style plug used on Optimate, Oxford products and many others. You can buy a connector that coverts from ‘type 1’ to ‘type 2’ but probably better just swap the lead to a type 2. most chargers here now come supplied with a type 2 lead.Hi Andy, did you ever use that battery tender plug on my bike? Keen to know who makes a tender to fit that plug.
